DX Spots using 6500 with Logger32
My system is Flex6500 with SmartSDR 4.2.20 on PC Windows 10 running Logger32 and SmartSDR
Within Logger32 I open the DX spot Telnet window and connect to RBN.
with the 6500 in CW mode and clicking on a CW mode DX spot the radio changes to the correct spot band and Frequency but the mode always changes to SSB.
If I change the radio feeding Logger32 to my K4D I note that the Spots work correctly and remain in CW mode, therefore I concluded that the problem lay within the Flex domain.
Having check all the menus in Logger32 as well as on the Flex I cannot find anything amiss or that would change the mode of the spot message always to SSB
I wonder if anyone else has seen this or has any further advice on why this might be happening.
Mal G3PDH
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHere is what I would do.
- Open the SmartSDR CAT an look for the N1MM Spot link (see picture). Click on it to highlight it.
- Click on LOG
- Now, test both radios
- Here is the fun part. Capture ALL the data and dump it into Claude or ChatGPT and ask it your exact question above.
- It will analyze the log for your band/mode changes and give you a good answer about what is happening in the communications between the radio and the logger.
Let us know what you find out.
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
