FR6400 & TRANSVERTER
I have a FlexRadio F6400. I’ve connected a 144 MHz transverter (Javornik) to it. It works excellently, but I’m having a problem when sending CW (Morse code) using an electronic keyer. When I use the keyer, two sounds occur: one is normal and in real-time, while the other appears with a half-second delay. So, when I press the key, I hear the expected beep, but then—after a delay—another tone identical to the first one follows. This is very annoying; sending via the electronic keyer is practically impossible because the second tone appearing in the headphones or speaker interferes with the first one. Does anyone have any ideas on how to solve this? BTW, when I switch to HF bands, CW and the electronic keyer work flawlessly, without any delay.
73 Dare S58M
