Save me from divorce - Flex6300 Fan noise
Dear friends,
My wife is about to divorce me if I do not fix the noise from my 6300 located next to our bedroom.
The radio is 24/7 on as a remote and is getting really noisy.
Can somebody please give me the specs of the fan (voltage and size so I can try to find an equivalent Noctua type. I had a similar exchange on my Icom IC7300 and the difference is HUGE..
    Be careful when changing the fan as the FAN RPM is used by the power controller in the radio to determine if the fan is working.
    Normally, they are pretty quiet, but if they start to fail (they are small) they need replacing. They are glued to 2 of the CPUs.
    You might want to try cleaning the radio internally as well. That might help.
    Good luck
  • on7wp
    on7wp Member ✭✭
    Are we talking about the same radio ? You say two small fans, I just found this picture (before opening mine as it is running as a remote 24/7) Is there another fan under the LPF assembly then ???
