Interfacing Slice Logger with JTDX and JT Alert
I am going to replace currently used HRD software with Slice Logger and use it together with JTDX and JT Alert.
Latest version of JT Alert does not list Slice Logger as one of the logging software which can be selected. Is there possibly another way of interfacing JT Alert with Slice Logger?
All comments from Slice Logger users will be appreciated.
Tom
  • Mick  W8BE
    Mick W8BE Member ✭✭✭
    SliceLogger does not need another app to forward logging data to it. Make sure it is on the same port as the WSJT-X UDP port. If you use multicast then you will need to use the correct group ip address. See below…
