SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
connecting and station list
I have just had to change my PC after a major failure.
I,m trying to re-install Smartsdr but when I try to get the 8400M and the the PC to connect it fails.
I believe the reason being that in the "SmartControl" mode the 8400M shows the name of the defunct PC and no alternative.
How can I resolve this?
I only use SmartControl and have no need of remote working
Running Win10 PRO
Thanks Roger G0IUW
O n the front panel touch Menu, then Front Panel. Touch the box by Station Name and a onscreen keyboard will appear. You can edit the Station name there.
James, thanks for that but the name(s) in question refer to the identity of the PC to which its trying to connect
Roger
You should be able to select the correct pc from the drop down beside the Station name.
Yes ok but the drop-down menu as in your photo ONLY shows the old defunct PC and not the new one
Roger
Have you checked your firewall settings to see if it's blocking the radio?
Can you run SmartSDR on the pc without using SmartControl? If so, and you cannot use SmartControl then you may need to do a Factory reset. Be sure to save your settings before you do the reset.
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
