DAX problem with Diversity mode
sq9orq
sq9orq Member ✭✭
Hi,
I encountered a problem while setting up my stations for CQWW RTTY and diversity operation. I'm using the Flex 8600 and 6600 running version 4.2.20.
Everything works fine when I have two separate slices running, each with its own assigned DAX channel. However, when I activate Diversity mode and assign DAX1 to Slice A and DAX2 to Slice D, DAX1 streams the audio signal, but while DAX2 is active, there is no signal present on it.
Previously, I had an issue where no audio signal appeared at all. The solution was to enable the "Listen to this device" option in the Windows recording sound settings.
It is possible I have a driver issue, though I have reinstalled SmartSDR several times without success.
