Problem with LOG Book
I’ve been using SmartSDR on my Mac. Today, I purchased SmartSDR for iOS and installed it on my iPhone, only to discover an unpleasant surprise: I opened my logbook and found it empty—as if it were a fresh installation. How can I restore my previous file?
  • Henkka
    Henkka Member ✭✭
    Hello Eugene,
    Are you using Local file or iCloud? Go to Logbook settings - Log file - Use iCloud. You should see your log on both systems. Also take into account if you have lots of QSO:s in your log it takes a while to load the log, wait minute or two and voila.
    It happened me once that when opening the Mac version of SmartSDR my whole iCloud log was somehow automatically erased. I was **** and contacted the developer, but he couldnt do anything. Luckily I had backup log on my MacLoggerDX.
    One is none two is one like the old saying goes. Let me know if you need any further info.
    Henkka OH5KNL
  • Eugene Bugrimov
    Thanks for the reply. The issue is precisely that cloud storage is enabled everywhere, yet when I installed the app on my phone, the log I had been keeping on my Mac simply vanished. It contained a couple of weeks' worth of contacts—normally I transfer everything to my main log—but it’s still frustrating. That said, I installed the app on my tablet in the evening, having first entered a single QSO into the log; everything worked perfectly, and that QSO is visible on all three devices.
    So, my question is: does the Mac save archive files or anything of the sort anywhere?
  • Henkka
    Henkka Member ✭✭
    Good question, perhaps this community has computer experts who can help on that.
  • K3CDY
    K3CDY Member ✭✭✭
    edited September 17
    Eugene -
    You could try logging into www.icloud.com on your Mac, then click on Drive to examine your iCloud Drive (which is accessible via the Files app on your iPad). Open the left sidebar, and click on Browse. With any luck, you'll see a folder created by SmartSDR for Mac, and your log may be there. You can also search iCloud Drive and also check for Recently Deleted.
    Also, on your Mac you can also try your Time Machine backup (you DO keep a backup, right? 😉). To access iCloud items, open any Finder window, then browse your Time Machine backups. Look for iCloud Drive in the left column, and start going back in time and hopefully recover your file(s).
    Lastly, there's one little-known location at: https://www.icloud.com/recovery you can examine. It goes a little deeper than the standard iCloud Drive and is specifically designed for data recovery.
    Good luck!
