How can II use a Alpha 9500 and a StepperIr 4 element
I would like information on connecting an Alpha 9500 Amp to my flex. 6500 and also getting the steppers with SDA 100 controller working with the radio.
Once I do this I am getting rid of the Yaesu FTDX 101D
John W7BO.
  • Gordon, ve7on
    Gordon, ve7on Member ✭✭
    I do not know about the Steppir controller but the Alpha 9500 is RF sensing so you only need the coax connection to make it work.
    73 Gordon, ve7on
    Hi John, the 6500 will easily key the Alpha 9500 key line. Connect TX1, TX2 or TX3 to the Key In jack of the amp. Use the TX Band Settings screen to select the TX port for each band that you want the amp to be keyed. In this example, I key my KPA 500 amp using TX1 on 160 - 6 meters. I key my 2 meter transverter using TX2 and I key my 2 meter amp using TX3.
    The SDA 100 needs to have the Transceiver Interface to work with the Flex. You would need to look in the SDA 100 manual for more info on how to use it.
  • David Decoons, wo2x
    I am using an Alpha9500 and SteppIR MonstIR with Optimizer controller with a 6400 at my remote station. I did things differently as I need full control. I am using a Raspberry Pi 5 with the USB from Aplha to the Pi and an FTDI USB to serial plus SteppIR S12 cable to the Pi. I run Node Red on the Pi which provides me with a web interface to monitor and control the Alpha, Optimizer controller and Orion 2800 rotor along with other equipment.
    In your case, to interface with local control, people have responded for the Alpha 9500 connections. Here is how to interface the SteppIR. It is outlined on page 12 of the Flex USB cable guide. You will need a USB to serial cable with FTDI chipset. Make sure to get a genuine cable. Some of the Chinese knockoff cables do not work correctly. You also need the S12 cable from SteppIR. They are back in business. If they do not have the cable, get the Pinot from them.
    https://www.flexradio.com/documentation/usb-cable-interface-guide-pdf/?srsltid=AfmBOoom97Hr5tv6imQNLnXnNlefE27NEaqWPzBQaj8iSL4SpoxMp4OC
    73 Dave WO2X
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Hey Dave…I was unaware that SteppIR sold wine!
    lol. I hate the keyboard on the new iPhone 17 Pro Max.
