SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Flex 6400 TX low power ... PA issue ... Looking for root cause
Our club's FLEX 6400 is in for repair at Flex. The radio worked fine for a couple of years, then the power output dropped to 40W and 60W in voice, data, or CW. TX audio quality and DATA is fine. No distortion.
The Flex tech says that the problem is with the PA module and he is repairing it.
So that this doesn't happen again, does anyone have any ideas what could have caused this?
Antennas?
- The 6400 has a built-in tuner
- It's connected to a Cushcraft R8 vertical and to a Palomar Engineers BAS-71 end fed wire antenna.
- The tuner is used with the end fed and it almost always manages to bring the VSWR below 1.5:1
If someone tried to tune and it failed, will the 6400 protect itself from high VSWR by reducing the power? Can this have cause the low power problem?
DATA mode?
- Can this problem be caused by users transmitting DATA at the 100W level, mainly FT8?
- We now use "iShareRadio" for club members and we set the limit for DATA to 50W
Voltage?
- The radio & repeater building (a quasi-Faraday cage) has no AC power. All DC is derived from a bank of batteries that provide 48 Vdc. So we have DC:DC converters
- During TX, the DC at the 6400 radio dropped from ~13.8 VDC in RX to ~12.9 VDC in TX at full power
- Could this low voltage have helped to create this problem?
- Our current backup, a remote 6600M. is powered from two ganged Willmore 48 Vdc:12Vdc converters. They are balanced and set to provide ~14.2 Vdc to the radio. In TX at full power, it doesn't drop below ~14 Vdc
Looking for your feedback so that we can take the appropriate measures to prevent this from happening again.
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
