VERY LOW powered speaker audio output
Does anyone have any ideas as to why I have very, very low powered speaker output audio level from my 6600? I know the jack itself only has a few watts out output but I'm running that thru a set of 60W powered speakers and with all the volume knobs turned up full, I can still barely hear SSB audio from the FLEX. Any thoughts?
Marv K7IU
  • Dewey WØYWW
    Dewey WØYWW Member ✭✭✭
    Check your Flex SSDR equalizer settings. Move sliders up as desired for both frequency response and volume output. Also, check audio volume slider on SSDR panel screen and computer, depending on how you have it configured, and your PC audio configuration, if PC is in the loop between 6600 and SSDR. Rarely, but sometimes, Microsoft updates change the PC audio configuration.
  • K7IU_Marv
    K7IU_Marv Member ✭✭
    Thanks, I'll check
    Hi Marv, make sure that you don't have PC Audio selected. Also make sure that your powered speakers have power and that they are plugged into the proper jack on the back of the radio. It is very easy to plug into the wrong jack.
  • K7IU_Marv
    K7IU_Marv Member ✭✭
    Dewey W0yWW,
    From what I gather from reading the Flex docs: if the PC audio butto at the top of the SSDR window is enabled then the slice audio is directed out the default windows audio devices, which obviously are then controlled by the windows audio controls. But if PC audio IS NOT enambled then the slice audio is directed out the powered speaker or headphone jack.
    I have powered speakers connected to the powered speaker jack and I am NOT enabling PC Audio. The powered speaker output is controlled via the EQ settings and the SSDR speaker slider but the level is still very, very low.
  • K7IU_Marv
    K7IU_Marv Member ✭✭
    Len K0RC,
    thanks, I've checked all of the connections several times. The level still seems extremely low.
    Marv K7IU
  • Dewey WØYWW
    • Is this something that changed, i.e., the speakers previously worked ok (volume-wise) with the Flex-6600?
    • With speakers disconnected and speaker audio volume turned to max, does individually touching the speaker audio plug tip and ring, cause speakers to emit a strong buzzing sound?
    • I previously owned a 6600, and experienced low volume with both speakers and headphones — which I fixed by increasing the EQ settings significantly (I increased the center frequency 1K to 2K ranges by 10 dB) and wider frequencies by lesser amounts.
