Maestro B no receive audio
all of a sudden, there’s no receive audio out on my maestro B
It was working fine the last time I used it yesterday yesterday today turned it on no audio out
Absolutely no changes to any settings.
I found one suggestion here to switch in menu audio setting from maestro to radio I did that several times without any result.
I will submit a ticket, but thought I would check here first if somebody has any suggestion
A picture would help of the Maestro.
Things to check:
- Bad coax cable — yep, it does happen - bypass everything and connect the antenna directly to the Coax connector on the back of the radio
- Is it only on the Maestro?
- Reboot the radio and retest
- Check the Audio choices in Settings Menu (Menu/Audio/Main Audio Out)
- AGC-T set too low
- Reset the radio if it isn't any of the above
radio reset …problem solved
thanks0
- 409 Community Topics
- 705 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
