Remove Legacy SMARTSDR Audio Ports from Windows 11
K5MDS
Member, Unconfirmed ✭
I am running SmartSDR 4.2.20 on Windows 11. I have about 30 audio ports listed. Most are legacy ports. I searched about removing them in the uninstall process but I must have missed that when I uninstalled old versions of Smart SDR. I also found a solution to find the drivers and run the install .bat files. But I can't find those. I tried uninstalling them from Device Manager but they return after reboot. Does anyone have a solution to remove them?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThe quickest way might be to reinstall v4.0.x and then uninstall it but this time, take the old DAX drivers with you. It won't mess up the v2 drivers as they are not related in anyway.
check the release notes. Uninstall old versions of SmartSDR. When prompted @Do you want to keep DAX drivers?”, say No.
I don't have any old versions to remove. They were previously removed and I probably kept the DAX drivers. Now I prefer to remove them after the fact.0
Installing an older version and uninstalling it worked. Thanks.0
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
