Aurora AU510-M Not transmitting on JS8
RayB
RayB Member, Unconfirmed ✭
Flex Aurora 510M, SmartSDR 4.2.20, Windows 11
When using JS8Call, my transmit audio is not making it to the transmitter.
I am in DIGU and the DAX Button is on.
I've created a FlexVSP COM port, and JS8 is shown as the active process
I'm using Kenwood TS-2000 as the configured radio
JS8call is receiving and decoding messages without an issue.
On the radio tab, the "Test CAT" button is green and the Test PTT button is Red.
Tune button turns on a signal - set to 3% max.
External tuner Palstar BT1500A producing a nice tune - just a sliver above 1:1
When I first turned up JS8call a couple of days ago it transmitted and received ok. But my match was not as good then, and it went into interlock shortly after that first success. I think I have cleared the SWR interlock but am not 100% sure. Powered down from the back panel for 5 minutes, then back up again. Set the system power limit to 50%. Set the band power limit to 25%. The system transmits fine on SSB phone.
The Aurora on/off switch is blue, turns red when its supposed to transmit, but there is no power coming out.
I've used iCom for years but am new to flex with the Aurora.
Appreciate any ideas you may have
