No TX audio on FT8
I am not able to get ft8 transmit audio to work on my local 8600 but I have a remote 6600 and it works on that radio. I've tried with my iPhone, iPad and Mac mini and still no tx audio. Then I tried SmartSDR version 4.2.2 and WSJT-X version 3.1.0 and still no modulation on TX for FT8. I checked to make sure I had the correct DAX under audio selected for 4.2.2. It does key the radio but no drive modulation. Is there something I could try? I have used the ai to try and figure it out but nothing has worked. I originally thought it was only a problem with the iOS SmartSDR but it is even on the pc. I have reset/removed power from the 8600 and rebooted it. I also thought it may be a LAN issue but I left home and connected via SmartLink from my phone and still no audio. Please help!!
Thank you
Mark, N5LPT
