Connect Winkeyer USB to Flexradio 8400M
Here are the issues that I am having getting this to work with my Flexradio.On the com port list Com7 has WKUSB 10On com port10 it has WKSMT 31.3When I did the WK3 Demo 4.2 and go into Setup I entered Com Port 10 and then pressed Open.On the bottom left it says WK SMT Version 31.03When I go into my Flexradio Cat I originally had Com Port 7 setup for the Winkeyer.I went into Edit Winkeyer Port and under Client Com: It will not show Com10In CAT COM it will allow me to set the CAT COM to 110.All I want to do is get this device to work not only with my Flexradio 8400M but have it work whereN1MM will now use the Winkeyer USB instead of the SmartSDR Winkeyer.My hardware settings are my Paddle is connected to the Paddle on the back of the Winkeyer USB andKey1 is connected to the Paddle Connection on the back of the Radio.And I know to change the Phone/CW iambic to off instead of Enabled.I figure the issue is a com port issue and to be honest I don't know how to fix this.Has anyone been able to get this to work without any issues?
Mark KB3Z
