NEW to smartsdr, Microphone NO AUDIO OUT, microphone ok , PTT ok
there is no profile for this so I use all DEFAULT. PTT work and and when I start talking no audio. I saw many people have same issue. what is the problem ?
Some possibilities:
1. Turn BIAS OFF (Crucial for the MH-31)The Yaesu MH-31 is a dynamic microphone. It contains a voice coil that does not use or want electrical power.
- Go to the top menu bar in SmartSDR and select Settings > Radio Setup.
- Click on the Phone/CW tab.
- Make sure Bias is turned OFF.
2. Enable "+20 dB Boost"Dynamic microphones like the MH-31 have a much lower native output level than the electret microphones.
- In that same Phone/CW menu tab (Settings > Radio Setup), locate the +20 dB Boost checkbox.
- Check this box to turn it ON.
- Without this preamp boost, your signal is likely too quiet.
3. Use only "MIC" input source
4. Turn off DAX.
/did not work. I tried your settings. I am in canada and region says USA . does it matter ?0
Not for audio. I would open a Help Desk ticket for this issue as well as one to get a TURF file for Canada.
I did 2 days ago iopened ticket and no help from the Help Desk . looks like the making TURF file by hand and will take couple of weeks.0
Just check by logging in again and look at your open ticket. I just had no apparent reply but actually it was there. Maybe not for you but worth looking if you haven't done so already. Normally they are quick to answer.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptions@Jacek J This video, while a bit dated, will help you out with some of the basic setup as it runs through some of the common features/commands. And, we don't update our GUI that often, so that still makes it helpful.
BTW, it sounds like you have BIAS turned off or a defective Mic.
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
