SmartStreamer4 v0.3.1 GA release
A new update is available for SmartStreamer4. I appreciate all the users (over 100 so far) and feedback that have helped shape this product along the way. Existing users will notice an "Update Available" button in their app. New users can download the latest release from github, or the project page below.
SmartStreamer4 is a windows companion for FlexRadio SmartSDR 4.x that can set up and configure CW and digital modes, then launch CW Skimmer or WSJT-X with multiple slices.
New in v0.3.1 is Dark Mode theme, and SmartDeck, an integrated panel used to change bands, antennas, and power, and to monitor your Flexradios telemetry. See the full release notes below.
SmartStreamer4 is built with FlexLib API 4.2.20, matching the SmartSDR 4.2.20 release. The program ships in a zip file with one self-contained Windows executable, no installer.
SmartStreamer4 v0.3.1The first release since v0.2.1. It carries the v0.3.0 development series, which was tested in the field but never published, plus the v0.3.1 work on top.
New in this release is SmartDeck, a compact radio control window for FLEX-6000 and 8000 series radios, along with a new Dark Mode window theme.
SmartDeck
SmartStreamer4 must first be connected to a radio to enable SmartDeck.
A new window that puts the controls you reach for mid-QSO in one small panel you can park beside SmartSDR. Open it with the SmartDeck button in the main SmartStreamer4 window.
Live telemetry. Forward power, SWR, PA temperature, and supply voltage, read straight from the radio's meters. SWR reads dashes below a transmit threshold rather than showing a meaningless number on receive.
Slice, frequency, and mode at a glance. The header names the slice you are controlling and shows its frequency and mode. Click the mode readout to step the slice through CW, LSB, USB, and AM.
Band buttons with per band memory. Press a band and the slice moves there. SmartDeck remembers the frequency, mode, and antennas you last used on each band and restores them, so coming back to 40m puts you where you left it. The memory persists across restarts.
RX and TX antenna. Buttons for whatever antennas your radio reports, per slice. Unused transverter ports are filtered out.
RF gain and AGC-T. Steppers for both, with the F1 to F4 accelerators the FRStack users among you already have in your fingers. They work while SmartDeck has focus. RF gain uses the range and step your radio reports, so it matches what SmartSDR shows for that model.
TX power and a one press QRP toggle. Press QRP to drop to 5 W; SmartDeck remembers the power you were running and restores it when you press again. Change the power any other way and the toggle stands down and forgets the saved value rather than overwriting your choice later. That includes SmartSDR, another client, and the wheel described below: rolling off 5 W is a manual power change like any other, so if you fine tune down to 1 W you are on your own way back up.
Mouse wheel on the readouts. Hover over the frequency, TX power, RF gain, or AGC-T readout and roll the wheel. No click, no focus, just hover. Frequency tunes by the step you have set on the radio; TX power moves one watt at a time, which is what makes working 5 W down to 1 W practical. One click of the wheel is one step, whatever the speed: full band changes belong on the VFO dial, and this is for fine tuning.
Stays where you put it. A pushpin keeps SmartDeck above other windows, and it remembers its position, width, and pin state between sessions.
Light and Dark themes
A theme button sits at the right end of the tab ****. It switches the whole application, SmartDeck included, and the choice is remembered. The icon shows the mode you are currently in: a sun while Light, a moon while Dark.
Upgrading
Download the zip file and extract the executable. Your settings, per slice configuration, and CW Skimmer setup carry over. SmartDeck starts with empty band memory and fills it as you use it, and the app opens in Light, which is how it has always looked. Switch to Dark from the tab **** whenever you want to.
If you are coming from v0.2.1 you are getting everything above in one step, including the work developed and field tested as v0.3.0 but never published.
Chris WX7V
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
