What version of AG do I have ?
I acquired an AG 8x2 Plus, serial number 211101/16. This doesn't appear to be the usual AG. Next to each antenna port there is a green and red LED. There is also a 9 pin connector on top labeled "AB switch control". On the bottom are the usual connectors and 8 position DIP switch.
Considering all the FW, HW and SW versions over the years, I'm a little hesitant to just plug it into the LAN and see what happens. Who knows - it could brick it.
My specific questions are:
- How do I figure out what version I have ?
- What SW will work with this HW and version ?
- I want to connect it to my 192.168.2.x network. What is the process with DIP switch 8 and my 192.168.2.1 router doing DHCP ?
- Which manual is the right manual for this version ?
Thanks and 73,
Steve, N2IC
Hi Steve,
The AG hardware v2 has four RCA connectors and the green A/B connector on one end. The other end has power, OM Module, network and two 15 pin Pint to port/BCD connectors. There are green and red LEDs next to each antenna port to show if the port is in use by the A or B "radio".
73 Dave wo2x
Also, you can compare your AG to the 1.2.1 manual pictures. If it matches the pictures it is a v1 AG.
https://4o3a.com/images/downloads/antenna_genius/documentation/archive/AG_Manual_1_2_1.pdf
If not it is a v2 and you can upgrade it to v4.1.16 firmware.
73 Dave wo2x
It's neither a v1 or v2. Close to the one pictured in
but it doesn't have the 4 RCA connectors and green A/B connector. Definitely not a v1 AG.
It's a unicorn.
73, Steve, N2IC
Any chance you can post a picture?
here’s a link to the v2.
https://4o3a.com/antenna-genius-8x2Does it look like those pictures?
You can also email support@4o3a.com with s/n.
73 Dave wo2x0 -
Thanks for the suggestions. I have it working with the AG 3.1.5 Windows app. The first thing it did was demand a firmware upgrade, which proceeded without incident. All looks good. It appears that my version has a 9 pin RS-232 connector on top, instead of the 4 RCA connectors. The device info says hardware version 2.0.
Steve, N2IC
ok, be advised the API is different between firmware v3 and v4.
73 Dave wo2x
- 409 Community Topics
- 705 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
