SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Inexpensive RF monitor for CW and SSB
OK, so maybe CW's not your thing. Just for you :-) I added a SSB mode to the software (see my previous 'CW' thread for a reference). This mode shows actual voice peaks of sampled RF audio. It still retains all the CW RF waveform measuring capability of the previous version described on the previous thread. You can now select between the two modes.
Again, the SW creates its own web server and automatically connects to WIFI. These views are taken from an ordinary web browser on your PC or phone w/o any loaded apps.
Here's an example of what the SSB mode can measure.
Setup page:
The shot below is a captured view of "Hello test" without any processor compression. Remember, this is the actual sampled RF output power. The set point reference was somewhere around 100w output. The reference can be easily set to your requirements and power levels. Of note here is the 13.3% average power and the 9.4dB crest factor.
Compare this to the waveform below with "NORMAL" speech compression set on the Flex. Average power rises to 18.3% and the crest factor drops to 8.4dB. Crest factor is a measurement of how "peaky" the audio is. Speech compression lowers the value
and in "DX" mode compression the crest factor drops to 6.3 dB and the average power rises even more to 28.8%:
The SSB mode SW needs some more work before it can go "prime time", but I wanted to show the power of this sampling approach. It won't show IMD products, but hey …what do you want from a $35 monitor?
73, Fred
K9SO
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
