Help understanding TCP message from the radio
K1FR
K1FR Member ✭✭
I am looking for some help understanding a radio response on the TCP channel.
I have written some Python code that sets four panadapters to four WWV frequencies and then processes the four DAX I/Q streams. The code runs for several hours, often 24. During last night's run, the radio started occasionally sending the following output on the TCP line which my code prints in its status output text:
 S0|wan enabled=1 server_connected=1 radio_authenticated=0 public_tls_port=-1 public_udp_port=-1 upnp_supported=1 public_upnp_tls_port=21000 public_upnp_udp_port=22000
Some online searching indicates that port 22000 is associated with SmartLink (which I do not use), but I am wondering why this just started showing up  last night? My main reason for asking -- is this message possibly an indication that some external source is attempting to connect to my radio?
Thanks for any info!
73, Tom
K1FR
  • Eric-KE5DTO
    This is a standard status message that the radio sends regarding SmartLink server connection status. I would expect that you wouldn't see this if you unregister the radio with SmartLink (requires physical access to the radio), but I haven't actually tested that in recent versions.
  • K1FR
    K1FR Member ✭✭
    Thanks much, Eric. 73, Tom K1FR
