Remoto
Hola el flex 6300 con la ultima version , se puede conectar en remoto?
Hi, can the Flex 6300, with the latest version, be connected remotely?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Cristo… Yes, the 6300 can be run from a remote location, just as all the other Flex radios. You will need to enable SmartLink and establish an account with it, to access the radio from the remote location.
  • David Decoons, wo2x
    The 6300 will need to have at least a version 2 license for SmartLink operation. You can load the latest version 4 software but the radio will maintain the current license so if the radio had a version 2 license, it will continue to have version 2 features but have all bug fixes up to current version 4.
    If the 6300 has a version 1 license, you will need to purchase the upgrade to get SmartLink as well as other features. Read the version 4 release notes carefully.
  • Cristo
    Cristo Member
    okey gracias
