SmartSDR v2.7.3 is Now Available
Tim - W4TME
edited May 2021 in Message Board
FlexRadio Systems announces the immediate availability of SmartSDR v2.7.3.
The SmartSDR v2.7.3 software release greatly improves the stability and reliability of your FLEX-6000 software defined radio. Once SmartSDR v2.7.3 is installed, FlexRadio strongly recommends not reverting to any previous versions of SmartSDR v2 to ensure the optimal user experience.
SmartSDR 2.7.3 can be downloaded from the FlexRadio Systems website. SmartSDR v2.7.3 is a general release containing software bug fixes and new features for version 2 of SmartSDR for Windows, SmartSDR for Maestro, SmartSDR for M models, SmartSDR CAT, and DAX.
Please download and review the SmartSDR v2.7.3 Release Notes included with the release package before installing SmartSDR v2.7.3 on your FLEX-6000.
CAUTION: If upgrading from SmartSDR v2.6.2 or below, this release of SmartSDR will result in two firmware update processes occurring on the FLEX-6000. The radio’s LED indicator will turn purple twice and the radio will reboot after each firmware update. Due to a software change that is specific for M model radios, the firmware upgrade may hang after the 2nd time the power button LED turns purple which will require resetting the radio as described in the Best Practices for Installing a New Version of SmartSDR for Windows section below.
If you are updating a remote radio using a VPN, having the ability to turn off and on the DC power supply and being able to reboot the radio using the REM ON connector should be a prerequisite before upgrading the FLEX-6000.
FLEXVSP NOTE: If upgrading from SmartSDR 2.6.2 or below, this version of SmartSDR will update the FlexVSP driver. The SmartSDR installation software will automatically remove the previous FlexVSP driver and install the new one. Please reboot your PC when prompted at the end of the SmartSDR v2.7.3 installation process to ensure the FlexVSP driver is installed correctly. The new FlexVSP driver is not backward compatible with previous versions of SmartSDR CAT. An unhandled exception error will occur when using previous versions of SmartSDR with the new FlexVSP driver.
Release Highlights for SmartSDR v2.7.3
Improved Internal Latency Performance and Reliability: SmartSDR v2.7.3 incorporates many new internal improvements that enhance latency performance and reliability. These changes result in lower RX->TX-RX transition times, improves firmware stability, provide for greater reliability, and resolve several CW timing issues. (#J8092)
Updated FlexVSP Driver: This version of SmartSDR for Windows contains an updated FlexVSP driver (v5.8.1) that is used with SmartSDR CAT to create virtual serial ports. The new FlexVSP driver is less susceptible to driver corruption related to Windows 10 updates and has greater stability and performance characteristics. (#J8956)
Multiple ATU Fixes: The ATU issues introduced in a previous version of SmartSDR v3 have been fixed. These include greatly improved tuning consistency and ATU memories are now properly restored when the memory feature is turned off and back on. (#J7956, #J7732)
New Panadapter Zoom Feature: The ability to zoom in and zoom out the panadapter display using the mouse wheel has been added to SmartSDR for Windows by pressing the <CTRL> key while adjusting the mouse scroll wheel. (#J8048)
USB Bit Cable Setting using Slice as the Source Fixed: The defect where selecting Slice as the source for a bit cable control line (pin) has been fixed. (#J7624)
Additional SmartSDR Fixes: In addition to the notable ATU, USB Bit Cable, and CW fixes, there are additional SmartSDR firmware fixes that are of importance. They include disabling VOX when in CW mode, Intermittent DAX and SmartSDR crashes, a crash using the Auto-Connect feature, Fixed setting the RF Gain when using a FlexControl, The user can no longer log in to a SmartLink account if there is no Internet access, corrected the S-Meter accuracy when receiving strong signals, fixed a crash when using FlexSatPC, and fixed a frequency rounding error in the Memory form when using transverter bands. Please see the Changelog for a comprehensive listing of fixes contained in SmartSDR v2.7.3. (#J7740, #J8222, #J8170, #J7767, #J7537, #J8077, #J7702, #J7790)
Multiple Maestro and M model FLEX-6000 UI improvements: There are several UI (user interface) enhancements and changes with SmartSDR v2.7.3. They include an updated SmartLink login windows that makes it much easier to enter SmartLink account credentials, the screen for setting SmartLink network settings is no longer obscured, the Info screen now contains the front panel IP address and MAC information, added buttons for finer grain control when setting slider values, double-tapping now opens memory entries and selects profiles, the Slice menu now stays open on band changes, A partially entered manual frequency change is cleared when closing the slice menu and added controls to enable or disable the Auto Connect to a Radio feature. (#J8068, #J8197, #J8061, #J7511, #J8103, #J8035, #J8002, #J8101, #J8008)
Multiple Maestro and M model FLEX-6000 Fixes: There are many software fixes for the Maestro and M model radios. The following are just several of them. The Version Select menu is now properly sorted by latest to oldest order, fixed auto-connect issues if another station is connected to the radio, fixed issues that caused an available slice not to open correctly, and fixed a crash when selecting an audio input. (#J3199, #J8316, #J8193, ##J8022)
New and Updated TURF Files: SmartSDR v2.7.3 contains a new TURF file for operators in Spain who are members of Protección Civil en España (REMER), expanded bands for Japan, and added a new TURF for Austria that include the newly allocated 60m band. (#J8300, #J8003, #J88286)
